bluePurpleOne.svgbluePurpleTwo.svgbluePurpleThree.svg
Smart support: Everything you need to know
Introducing smart support – our clever tech that proactively keeps you online. Here you can find information on how it works, tips and tricks for boosting your connection and some handy FAQs.
We’re one step ahead with easy, proactive fixes
Whether you’re downloading huge files, running your home office or TikToking on the loo, we know staying connected is everything. That’s why we’re revolutionising the way we keep people online with our smart support.
Using clever tech to check broadband performance in the background, we can catch serious issues – or anything amiss in your first 14 days with us – and try to get in touch with easy, proactive fixes as soon as possible.
Smart support is available to everyone with Virgin Media broadband, at no extra cost – prioritising people with the most serious connectivity issues first. It also covers WiFi around the home, letting us know if you need a little help with your connectivity. Plus, we’re working hard to bring the complete smart support service to even more things, like IP TV. Stay tuned.
How does smart support work?
For your broadband connectivity
Automatic monitoring
Relax knowing we’re monitoring your broadband performance in the background.
Step-by-step help
If we spot a serious issue with your broadband connection, we aim to reach out with easy, proactive fixes as soon as possible.
Overnight fixes
If you don’t have time to try these fixes on the day, we’ll work to resolve the problem overnight while you snooze.
Expert engineers, at the ready
Tried the simple steps but still having connection troubles? We’ll send you an email with a link to book a free engineer visit at a time that suits you to get everything in tip-top shape.
For your WiFi coverage
Now, smart support also covers WiFi around the home for everyone, letting us know if you need a little help with your connectivity.  For this, the process is slightly different:
  1. Proactive WiFi watch
    We identify households with poor WiFi.
  2. A fix with new kit
    If we spot a serious WiFi problem, we’ll offer you a WiFi Pod or a newer Hub wherever we can.
  3. Sent with QuickStart
    If you accept, we’ll send your new kit as soon as possible – with no need for an engineer.
  4. Ongoing monitoring
    We’ll keep tracking your WiFi to make sure everything’s installed correctly and your connection improves.
  5. Handy tips and tricks
    We’ll follow up with more guidance if needed – like how best to position the Pod within your home to get the most out of it.
Tips and tricks to boost your connection
Make sure your cables are securely connected to the bottom of the wall socket.
Follow the cables from the wall to the Hub and Virgin TV box (if you have one). checking that there aren’t any kinks in them.
Tighten any loose connections, making sure they’re as snug as they’ll go by hand. If the cables have push-fit connectors, make sure they’re secured as well.
Finally, try resetting the Hub back to factory settings. If you've made any changes, like updating your password, you’ll need to redo them once the Hub’s been reset.
Looking for more support?
Check out our help pages.
FAQs
Legal stuff
Smart support: subject to availability. Monitoring connectivity to Hub. Free engineer visit excludes misuse, neglect and accidental damage.
Smart Support WiFi: subject to eligibility and stock availability. Monitoring WiFi coverage. Guarantee and eligibility for Hub/Pod do not cover broadband faults or network outages. Hub/Pod available at no extra cost. Our latest Hub/Pod requires self-installation and is only available via home delivery. You won't be charged for home delivery. To activate the Hub/Pod, please follow the instructions provided. Virgin Media reserves the right to amend or withdraw this offer at any time.
