Virgin Media O2 Logo in white
Tips to make your home WiFi more secure
Between extra guests and freshly downloaded games, chances are that your WiFi worked extra hard over the holidays. Keep reading for our quick and easy tips on protecting your WiFi security
Published
Wed 17th July 2024
It’s always a good time to make sure your WiFi security settings are up to date but if you opened your home to lots of guests or connected a lot of new devices to your broadband, a WiFi safety check-up is more vital than ever. Here are five simple ways to boost the online security in your home.
1. Consider your Hub’s position
You might already know that finding a central spot in your home for your Hub (otherwise known as a router) makes sense from a signal strength and connectivity point of view – but finding the right spot is also key if you don’t want to share your WiFi with a neighbour. If you position the Hub away from an exterior or shared wall, it helps to keep your WiFi signal confined to your own household.
2. Check your connected devices
It’s easy to check how many devices are hooked up to your WiFi by downloading the clever Connect app. You’ll find them all listed in the “My devices” section. Spot any unfamiliar devices lurking there? You can pause or disconnect them from your WiFi immediately using the app.
3. Change your WiFi password
All Virgin Media Hubs (as well as most routers) have a unique passphrase that you’ll need to access your WiFi. We suggest that you change this passphrase regularly to something only the members of your household will know.
And remember, the best passphrases include at least 12 characters with a mix of upper and lower case letters and numbers. The simplest way to change your password? Via the Connect app, of course – just select “WiFi Networks” from the menu in the Broadband tab.
4. Disable the broadcast of your SSID
The SSID (Service Set Identifier) is the name given to each Hub network – it’s the one that appears on your device when you or another user are scanning for available WiFi networks. But did you know that once your Hub has been set up, you can prevent anyone nearby from recognising your SSID? On the “WiFi Networks” section of the Connect app, you can also swap the default network name and password for something less recognisable. For more information about changing your Virgin Media WiFi password and network name, click here.
5. Keep your Hub up to date
The firmware in your Hub monitors the security for your network, so it’s good to reboot your router once a month to make sure it’s running with all the security patches and updates it needs. Need a little refresher on how to do reboot your router? Well, it’s as simple as… turning your Hub off and on again. Yes, really! Once the power is back on, it might take 5-10 minutes for the Hub to start up again.
Virgin Media Connect app: Requires compatible iOS/Android mobile or tablet. Virgin Mobile customers: the app will work on a device where a Virgin Mobile SIM is present and setup has been completed. Virgin Fibre customers: the app will work on a device where setup has been completed using My Virgin Media account details. Virgin Fibre customers can use the Connect app on up to 7 devices at any one time and benefit from Virgin Media's WiFi hotspots whilst out and about. For setup: Mobile data connection required for Virgin Mobile customers. Internet (mobile data or WiFi) connection required for Virgin Fibre customers. UK only. Experience varies by location and number of users. It’s not always possible to guarantee that we’ll be able to offer this app on every device, platform and operating system version or variant. Terms and conditions apply.
