Virgin TV 360 is your new trusted explorer when it comes to suggesting the telly we think you’ll love
By Virgin Media
Finding your new favourite show is probably one of the most arduous tasks in modern life. Don’t get us wrong, we’ll binge our favourite shows all the way through at least three times a year, but sometimes you need something fresh. A flash of inspiration. A proper good telly recommendation.
With Virgin TV 360, as well as telling you what everyone else is watching, it’ll also dish up some recommendations we think you’ll love. And thanks to Profiles, the picks will be personalised just to you. Simply…
A. Press the Home button on your Virgin TV 360 remote.
B. Choose Box Sets & Movies in the menu bar.
C. Select either Suggestions for you for personalised picks, or Recently added for new shows.
You can also find out what’s trending from our pick of the shows from up to 30 days ago, handily sorted so you can get to the best stuff quick. Simply…
B. Choose Catch Up in the menu bar.
C. From here, you can filter by Day, Channel and Genre.
Did you know you can get the most personalised recommendations by setting up your own profile? Simply hit the Profiles button on the side of your Virgin TV 360 remote. Either select your profile, or select + to add a new one.
Want even more Virgin TV 360 tips?
Want to discover the secrets of your new remote control, check out your channel guide or find out the best things you can ask your telly do? Find all this and more here.
Virgin TV 360 Box: Minimum of M50 Fibre Broadband required for operation. Boxes require a HDMI cable to connect to your TV.
